Configures the ID used by each device when automatically forming an adjacency with an BGP Auto-peering neighbor.
auto-peering | Specifies Auto-peering. |
one-config | Specifies changing the BGP Auto-peering OneConfig configuration. |
id | Specifies configuring the BPG Auto-peering ID that devices advertise to neighbors. |
none | Removes the current ID. |
id | Specifies the ID. |
N/A.
All devices in an Auto-peering cluster have the same ID. Neighbors with different IDs must match the Remote ID table.
The following example configures the ID as "123":
# configure auto-peering one-config id 123
This command was first available in ExtremeXOS 31.1.
